Charger to battery wiring
BobT
Sep 29, 2008
239
Gulfstar 37 North East River, Chesapeake Bay
Getting ready to put on a solar panel. I've ordered a 65w panel & Morningstar controller with dual outputs for my two group 24 batteries, wired in two banks with the 1/all/2 switch.
The P.O. had installed a 110vac charger (Rayjeff 15-3) and ran the charging wires to the studs inside the selector switch. It would be mighty convenient to send my solar charge the same way but I haven't seen it shown in any examples I can find. So, how bad an idea was it? Of course the existing wires are not fused either.
Apr 22, 2011
979
If the PO ran the two ac charger wires to the #1 and #2 battery switch studs, the charge will always go to the two batteries regardless of the switch position. No problem there, it's just a convenient place to connect to the battery circuits. Your Morningstar controller with the dual output can follow the same path. You might find it more convenient to connect the solar controller in series with the battery charger to simplify the wiring.
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
I am curious to know why you would recommend this, why you think it would simplify things, and whether it would actually work.
I don't think it's a good idea, and I can't imagine why you would do that.
zeehag
Mar 26, 2009
3,198
in my ericson i had the solar panels and controller wired to the breaker panel with their own breaker. i wish now i had that set up in this boat as sometimes i need to turn off my solar charging--and now i can only use a towel to shade them....
11,772
Why would you need to turn off your solar panels?
BobT
Sep 29, 2008
239
Right now the taps on the AC charger also feed an analog battery monitor that has a pointlessly small scale. I'm counting on the Morningstar monitor to be a large improvement.
I can't see a reason why not to feed the system at the switch with its beefy cables. It makes more sense than running more hot wires thorough bulkheads and into battery boxes.
I intend to fuse these wires as close to the switch as poss.
Beneteau 323 Annapolis MD
... and ran the charging wires to the studs inside the selector switch. It would be mighty convenient to send my solar charge the same way...
I mounted my Morningstar Solar controller in the nav panel, and wired in it at the breaker panel to the two heavy (#6?) wires that come from the batts to the panel. They're fused at the battery end. 6 is a bigger wire than would have added, had I done so, so it is a better plan.
