Jib downhaul and line routing
Bilbo
Aug 29, 2005
1,265
Catalina 22 Ohio
Have you actually tried it? I've been doing if for years on my C27... the wind doesn't rush under the main as you suggest.... besides your sheet controls the lower part of the sail and the downhaul will control the rest.
Well, there is wind that will come underneath the main when sailing downwind and when on a reach, the side winds will carry the foresail out over the water. I have tended to lower the sails while heading into the wind but I tend to not heave to just to keep fwd steerage. As a matter of fact If I'm headed directly into the wind, I would probably also have started the outboard.
As far as dropping the main first..... that's another discussion... but we were talking about the advantages of the jib downhaul....I especially like it because I can drop the jib on the foredeck going downwind without going forward.
I 'd agree with not going fwd. . For my situation, I'd use the downhaul to keep the jib down if the winds are up where the waves may make a trip to the foredeck dicey.
Stu's suggestion to heave to is certainly a good way to do it....but you may not always want to turn upwind just to drop the headsail... your intention may be to change headsails... a spinnaker or drifter for instance. In which case you don't need to add extra maneuvers..
I don't mind changing course when lowering sails as I'm not usually in a hurry. In the instance of replacing the sail with another, I'd most likely keep the replacement sail down below until the foredeck is clean. So, it's two trips to change a sail. I'd also be very cautious about going fwd. in a heave to situation if single handing, the boat would swing around. If it were really getting nasty, I'd even consider dropping the anchor to maintain location on our lake. If I have another competent pilot, the situation of being underway would probably be safer.
One thing that I'd mention is that I recently changed out the block at the bow for my downhaul. I changed it to a newer but smaller one. That isn't so good because the downhaul line tends to kink and catch out there after the sail is down when I'm organizing the boat for docking after the sails are stowed . So, I'd suggest going with a decent sized block that is a fair amount bigger than only what's necessary for line size.
You can heave to in nice conditions, too. :)
The point is to heave to and stay in the cockpit, with your halyards and downhaul led aft, not at the mast. Heave to, drop the jib and sail off on the main, drop it later whenever you want.
Bilbo
Aug 29, 2005
1,265
Catalina 22 Ohio
Your very correct Stu as always but I've found that the 22 sails a bit better with the jib alone rather than main alone.
GDTRFB
Aug 14, 2011
70
Catalina C22 Kenmore, WA
I use a continuous line that is tied off on the uphaul schackle.
I use an eyelet that clamps to the pulpit stantion. Then it goes aft on the port side back to the cockpit. I also have a small cleat on the port stantion by the cockpit to tie off the downhaul. From there it goes through a jamb cleat, to the organizer block, another block at the mast plate, up the mast to the sheave and back down the fore stay to the shackle where the other end of the continuous up haul/down haul halyard is tied off. some picts are attached.
Paul
Jun 5, 2012
23
Catalina 22 Marshall Ford on Lake Travis
Thank you all for the wonderful advice. We started off just making the small adjustment of adding a little block and 3/16" line for the downhaul and temporarily ran it inside the lower shrouds to an unused cleat by our port side winch.
Big, BIG smiles from the missus who didn't have to leave the cockpit to mess with the sails on Sunday. I'm still thinking a bit on how to run things permanently, but for now the main problem is solved.
