need more info
yes a 9hp is big for your boat, but if you run in fast currents, headwinds, or big seas on the bow the extra hp would come in handy I think. A 6hp extra long shaft would be just right. You need the extra long shaft to keep the motor in the water when you go forward, or with choppy sea conditions. The 9hp would be heavier and harder to take on and off, or tilt up when sailing. You don't mention if its 2 or 4 stroke? I like 2 strokes for their lighter weight. I had an 8hp 2 stroke sailmaster extra long and an 8hp 4 stroke high thrust extra long shaft. The 2 stroke was a whole lot easier to lift on and off the bracket by myself, the 4 stroke took 2 people struggling to do the same thing. I used them on a #4500 oday 25 and they were plenty powerful for all that I did here in the central gulf of mexico. The boat will only go so fast under power no matter how much motor u use, hull speed. I too used a seagull, in fast current I could walk faster sometimes with it maxed out. The bracket mount is another issue to deal with, can it handle the extra weight. I can't remember if you have a well and transom to mount motor or if mac21 uses bracket.
