Raymarine ST4000 Mk II lever issue
576
Island Packet IP31 Lake St. Louis, Montreal
Ladies and gents
My Raymarine St4000 MK II autopilot has developed a very annoying habit.
When it is engaged (lever down) the back and forth motion of the wheel, as the pilot corrects the course, will move the level to a position half way between fully engaged and disengaged.
I have tried adjusting the belt tension without and difference and have opened the using to make sure it was clean and all parts in good condition.
Any light anyone could shed on thow to resolve this would be greatly appreciated.
Cheers and thanks
Matt
Tim R.
May 27, 2004
3,626
It sounds like the cam is not adjusted properly.
Dec 4, 2003
90
Hunter 356 sandusky ohio
Mine has done that from time to time. There is a small screw on the lever that can be tightened and that should fix the problem.
Oct 25, 2011
576
Thank you everyone for your responses. Time to visit the boat and play!
Matt
Jun 21, 2007
2,118
Yes, this does help. However, be careful you don't over-tighten the screw. It threads into plastic and is easily stripped. Happened to me. I used the misfortune to make the lever to cam joint more robust than the original design. Sorry, but I don't remember exactly what I did! But I've had no troubles for a year now. Prior, I needed to tighten that screw every few months.
rardi
Nov 12, 2009
279
J/ 32 NCYC, Western Lake Erie
Thanks, Ron, for a simple solution.
Since we bought our boat 4 years ago our auto pilot would always dis-engage. I asked Ray Marine about this at a couple of different boat shows and no one offered your simple solution. I had been using a shock cord loop to keep the auto pilot working, but tightening the lever screw worked, and it is so much easier using the auto pilot now. Thanks for such a simple (for a change) solution.
