So Which do you use and prefer? I have been adding some marvel mysteryOil additives, and talking about them, is something that makes most normal decent folks, grow hair, and howl at approaching full moons. Seems to bring out the worst in people. I have two dollars to bet, this thread will grow fast, and as sides are picked, name calling, and worse will start up, till a moderator closes the thread, with everyone angry at everyone.
My two cents, diesel fuel today is junk compared to before they changed it a few years ago. It is formulated to work in modern diesel engines. An older engine, made before they reformulated it, is not going to work nearly as well on the new stuff. It only gets by. The new fuel, also can and will allow the growth of mold in the fuel tank, lines and engine. That is expensive to clean out.
Yes, everyone should be putting diesel additives in their fuel, and they are not all the same.
Let the tomato throwing begin. Lol
As much as I like MMO in the crancase, I have never added it to fuel. It has Stoddard Solvent in it, which I am not sure a diesel really needs to run on.So Which do you use and prefer? I have been adding some marvel mystery
oil, and a little off the shelf diesel fuel booster from my local grocery store.
Pat
I've only used MMO in the oil, not fuel either.....As much as I like MMO in the crancase, I have never added it to fuel. It has Stoddard Solvent in it, which I am not sure a diesel really needs to run on.
I could only tell a difference on engines that needed work, but Dexron ATF is the only thing ive seen really do anything, at all. Ive seen some rough hammerers smooth out and really quiet down after a good dose of dexron. But some the same could be done by cleaning the injectors. suggesting the ATF is the lazy mechanic way? Maybe not, it also cleans the combustion chambers and rings through higher detergent properties and ignition temps, which both clean, while offering higher lubricity. Cheap, and effective, but dont put any in your car, its got red dye.I've only used MMO in the oil, not fuel either.....
is there a brand of diesel fuel additive you use....I've used several, but could never tell a difference. Pat
