Single line reefing setup
2,809
Ericson 29 Southport..
Stan, remove the gauge, and cover it with a round piece of cutting board material, holding it on with a little sealer. The board is 2 bucks at walmart, and you could remove it later when/if you find an instrument you like, without recutting the hole.
Or a round piece of teak with the outer edge routed round.
StanFM
Jun 26, 2012
276
S2 7.3 Lake Pleasant, AZ
That sounds a lot cheaper than the $30 poly wood panels at the boat shop!
Stan
