My cover was trashed in spots. The wire looks fine, no broken wires and no rust, but the failing cover made the safety line look warn out.
I noticed lots of room inside the stanchions for a larger covering. Off I went to ace hardware. In the plumbing section they had a white translucent PVC tubing made to send water from the wall to the fridge ice maker. The tubing was large enough to fit over my lifelines (just barely) and small enough to fit inside the stanchions. Perfect, plus it looks good!
Because the line is translucent, I can see inside to see if water is acting on the cable.
Just a few cents a foot cut to any length.
Looks better than new and should last many years.
We do not sail in the ocean, small lake in Nebraska where you are always close to shore. We are fair weather sailors. If I were out away from land, I would only replace the whole line.
We tend to lean on the stanshions far more than the safety line. I replaced the stanshions with taller, stronger ones.
