Has anyone had a similar problem with the st1000 or other models drawing too much power. Even when the battery is full it will cause the low battery warning on the radio and gps to go off. The warning sounds only when the motor in the AP actuates. I have a feeling that the motor may need to be replaced. The rod moves easily and is unrestricted.
Has anyone else had the same problem and what was the fix. I should mention that I have them on the same circuit breaker as the gps and radio, but I can't see how that would make a difference.
