Cleaning / lubricating rudder shaft
437
Beneteau Oceanis 361 Clipper --
My rudder (Beneteau 361) sometimes gets "sticky" to turn (in general, not while sailing) and I am sure it's because the GRP shaft around the upper bearing (teflon(?); some type of plastic anyway) needs cleaning. Yes, the proper job is to drop the rudder and clean it but cannot do it now, since it's in the water.
Is there any sort of oil I could use to clean it and lubricate it?
Thanks
7,745
Alden 50 Sarasota, Florida
The usual cause for steering problems such as you described are worn or broken bearings or a bent shaft. Cleaning or lubrication obviously won't fix either and the only way to tell is to remove and inspect them.
Nov 23, 2009
437
A friend with the same boat and same problem, dropped the rudder, cleaned it and since then (2 years ago) is really smooth. Worth trying the easy way first, but cannot drop the rudder now.
I sometimes spray wd40 on top of the rudder shaft (a really small area above the bearing that you can actually see the shaft), with the hope that some will get between the shaft and the rudder and clean it a little bit. The I spray a lit of bit of Mclube one drop. It does make a difference but doesn't last for long. I need to find a cleaning "oil" or something that could dissolve any dirt accummulated there but not damage the bearing or the shaft.
(I once tried silicone spray and was a disaster. The helm almost got stuck for some hours!).
PS: The bearing is nylon (Ertacetal)
PS2: Probably I need some kind of cleaner/degreaser that will not damage GRP or the bearing. Could "isopropyl alcohol" be the answer?
