Scheafer stanchion base mounting
RAD88
Dec 15, 2008
163
Hunter 30 Glen Cove, NY
Is there any good reason why I couldn't file the 1/4" mounting bolt holes square to accept a carriage bolt? Wouldn't it be easier to tighten with only 1 person? Wouldn't the carriage head spread the load over the base plate better and seal out water better with butal tape?
Just a thought.
Jun 21, 2007
2,118
Creative idea. But a lot of work to square up all the stanchions' bolt holes?
We've got different boats, but my stanchion bolts also go through the deck frp and are secured by a nut from inside. For one person maintenance, I've had success by locking vice-grips on the head of the bolt. Then with a socket wrench on the nut from underneath, the bolt might turn a 1/4 rotation or so before the vice grips come up against something firm. The toe rail in my case. Then nut tightening can continue without the bolt turning anymore. A picture of the two bolt heads of my stanchion bases is attached. It is a precise trick to get the vice-grips firmly on my bolt heads.
Another idea might be to purchase 1/4" allen head bolts. These have a nice straight barrel head for vice grips to lock on to. Or maybe the allen wrench itself will seat snuggly enough to also wedge up against a firm part of the stanchion base.
I'm not advocating this as your "solution". Just the first thing that came to my mind as another alternative.
NYSail
Jan 6, 2006
3,187
Beneteau 423 Mt. Sinai, NY
Just use butyl tape under the stanchion and you will have no leaks. The stuff spreads nicely when preasure is applied and if put on correctly will seep into all voids around bolts etc....
Thanks Maine Sail!
Just a thought.
Yes, butyl tape is the way to go.
I've done it with vice grips and Phillips head screws. Carriage bolts might be easier. Not a bad idea.
Sep 4, 2007
795
Hunter 33.5 Elbow, Saskatchwen, Can.
I like rardiH36 idea not sure if you can find SS allen head bolts though. The person who designed philips head screws should be shot IMHO
Jun 21, 2007
2,118
Our local west marine has them. Pricey though. Or google 316 stainless cap screw 1/4" allen, etc and all sorts of stuff shows up. Another way that just occurred to me is to maybe use hex head screws. They would accept a vice grip grip on them.
Agree that phillips head screws can be not fun. But generally a better purchase than straight slots. Square drives are nice.
Aug 20, 2010
1,399
Oday 27 Oak Orchard
The correct terminology is 'button head cap screw' and are readily available from McMaster Carr in stainless.
