Sail story and teaching point...
227
Macgregor 26X Michigan City, IN
Went out with a sailing buddy late yesterday - did some really nice sailing. Same boat, different levels of experience. My partner could get us up to 5.5 knots at 30 degrees near reach/close hauled. I could get us up to 5 knots at 60 degrees near reach/close hauled or later, 4.5 knots at a beam/broad reach. :D
Waves and wind began picking up (small craft advisory today), furled the Genoa, went behind the breakwater, started the outboard, and turned my 97X into the wind to lower the mainsail. Two of my sail ties blew off the cabin top into the water before I cold wrap the main with the. Recovered one from the water, figured the other one had sunk. Tried to start the engine - it shuddered and shook considerably. We are a couple hundred feet from a rocky shore. Raised the engine, the other sail tie was wrapped around the prop. Shut everything down, buddy went behind the cockpit and unwrapped the sail tie. Lowered engine and all was well (plus I had both my sail ties back). Could have been a bit more hairy. :eek:
Lesson learned: stuff the sail ties into my shirt (or perhaps put some velcro strips on the cabin top. ;)
628
Legnos, Starwind, Regal Mystic 30 cutter, 22 trailer sailor, bow rider NEW PORT RICHEY, FL
sail ties
You might try starting motor before dropping your sails? It might help you keep boat pointed into the wind and should you be face with another situation might help get you ou of trouble. Or, decide to douse sails a bit further out with sea room to alow for problems without running the risk of grinding on lee shore. In windy/rough conditions clear all decks! Stow everything that could break loose or slide around and possibly go overboard- I had an anchor and rode lying on my fordeck with just a bungy strap over the pile, well while I was woohooing it with the 25k winds the anchor slid over the side and the helm became difficult-anchor did'nt set but the drag was weird. I dropped sail and retrieved anchor and rode and sailed on,lesson learned.
My Morgan has a long strap(nylon i think) that runs bellow the boom and sail ties are sewn to this strap every two feet or so. That way the ties are never hard to find or go missing or overboard but they are always there below the boom when sailing, not too pretty but functional.
Feb 16, 2011
227
Thank you for playing.
The outboard (50HP Merc) was started - that's how we turned into the wind. :D
Like the idea of the strap below the boom.
kenn
Apr 18, 2009
1,271
CL Sandpiper 565 Toronto
We have this arrangement. The under-boom line is actually a double run of 1/4" bungee material with plastic hooks threaded on. it's very convenient.
Oct 2, 2008
3,815
Pearson/ 530 Strafford, NH
Instead of sail ties we used shock cord with corks from wine bottles. Every once and a while I'd lose the grip on one and it would shoot into the air. Since we had plenty of corks and willing drinkers, the effort was graded for style and distance.
All U Get
Jan 10, 2009
590
PDQ 32 Deale, MD
Sail ties in the prop is a new one. Bum luck.
I would add that having the anchor ready to go in seconds is always a good idea. More than once I have found that to be the best answer, particularly when sailing alone. Once the hook is down, you have time to calmly solve the problem. It can work in surprisingly tight spaces if the drill is well rehearsed and no time is wasted deciding.
Jun 1, 2004
8,351
My partner could get us up to 5.5 knots at 30 degrees near reach. I could get us up to 5 knots at 60 degrees near reach or later, 4.5 knots at a far reach. :D
What is a near reach or a far reach..... and your degrees mentioned refer to what?
LuzSD
Feb 21, 2009
1,009
Catalina 30 San Diego/ Dana Point, Ca.
me too, same question.... Joe, Stu and Higgs!
Also, don't understand why the engine was started again... did you turn it off while recovering the one tie you did get??
Ties have never been an issue....... we either stuff one in each pocket and then reverse the order as they are tied on.....or they go around my neck on the boat we crew for.... never ever had one even budge no matter the conditions.
weinie
Sep 6, 2010
1,297
Lesson I learned. Some outboards can be started twice in the same paragraph.
Just like Obama's teachable moments, this makes so much sense.
:bang:
Feb 16, 2011
227
Nice point. My Plan B was to unfurl the genoa and get back out to sea. ;)
Feb 16, 2011
227
Yes, we turned off the engine before raising it or putting any hands anywhere near it to unwrap the sail tie.
May 4, 2005
4,062
fwiw,
I run a bungy cord(s) under my boom, with clips. when I drop the sail, I pull the bungy over the mainsail, and clip to the other side of the boom.
later I attache sail ties.
its the fastest way to contain the sail, and always ready to go.
Jun 12, 2010
936
Oday 22 Orleans Marina, NOLA
I carry the sail ties in my teeth, I'm pretty sure it makes me look cool, too.
227
That's a pretty nifty idea.:dance:
fwiw,
Jan 6, 2010
1,519
Joe's question
Joe,Based on your question, see the attachment & print it out. If you caan put it into a protective sleeve, keep it in the cockpit & practice the different points of sail & their names.CR
