Retrofit new rudder
5
ODay Mariner Roque Bluffs, ME
I've just purchased a new rudder for an older 19' ODay. The original kick up assembly is in fairly good shape, but the old rudder had been chewed up by the prop by a previous owner. The new rudder I ordered from D&R Marine is smaller in width than the old rudder. How should I shim the new rudder to fit within the metal cheeks of the old tiller assembly? Do I fabricate wooden shims on each side? Metal shims? What type of wood?
kenn
Apr 18, 2009
1,271
CL Sandpiper 565 Toronto
How much shimming is required - 1/8" each side? More?
Gunni
Mar 16, 2010
5,937
Don't use wood if you want the rudder to move, wood swells and binds. Last time I did some rudder shimming I found sheet teflon and cut it to fit the application. Delrin and Nylon are both cheaper alternatives.
Oct 18, 2007
707
Macgregor 26S Lucama, NC
Go to WalMart & buy a cheap plastic cutting board of the right thickness, and cut your shims out of it. No rust, no swelling, no painting, & cheap! -Paul
Jun 26, 2012
5
Perfect! Functional, original and affordable.
Thank you so much.
