Here's the situation. I was heading into Biloxi, in the east channel. It is only a little over a mile long, and fairly narrow. Skinny water on both sides. I have a thunderstorm pounding me pretty good. 30+ knots and a very nasty following sea. About half way up the channel, the wind shifts, and picks up. Gusts approaching 60 knots, dead on the beam. The boat is pitching with the following seas, and heeling over 35 or 40 degrees to port. Wallowing real bad. I'm managing pretty good, but it's work. All of a sudden something goes off, sounds like a AK47, on full auto. Very loud. And sounds like it's coming from under the boat. My mind is trying to solve two problems at once. What is wrong, and what am I going to do if something breaks. There is no way I can get anything done in this channel before I get blown out of it, and find the bottom. I throttled back to about 1500, the frequency of the noise reduced as the RPM came down, but was just as loud. Then after a lifetime, it just faded away. Real time less than a minute. About 20 minutes later the exact same thing. Again after less than a minute it faded away. And before I got in, one more time. As soon as I got behind Deer Island, into calmer water, it was gone for good. I checked everything I could think of. Oil pressure was a steady 55lbs, water temp @ 135. I thought maybe something had shaken loose and was hitting the coupler. NADA. Today I took her out and played around in some fairly snotty conditions, but could not make it repeat, but I couldn't duplicate the conditions. I can find absolutely nothing wrong, anywhere. Any of you gearheads have any ideas. I have a theory floating around in my heat, but am going to wait and see if anyong else has the same idea.
