Bimini, traveler and water.
12
Hunter 426 De
I just had a bimini and dodger put on our Hunter 426 and they can not come up with a method of keeping the water from coming into the cockpit. It is flowing around the traveler and down the SS tube frame. It there a standard way to approach this?
Jan 4, 2006
7,787
For the Cost of a Photo of You Dodger ....................
.................... you'll probably receive at least a half dozen expert solutions to your problem.
Jun 2, 2011
347
Hunter H33 Port Credit Harbour, ON.
On my 33 I have plugged the holes in the arch with plastic plugs and I have diaper like pieces that attach to the arch tubes, on the underside at the end of the stainless steel plate. The diaper pieces direct the water that leaks off the arch to the outside of the side curtain of the enclosure. The pieces are installed with Velcro but some of the copies that have been done are held on with snaps. My enclosure is virtually water tight.
