I would like to know if anyone owns a MacGregor, any model, that does NOT get water in the under seat storage during heavy, or prolonged, rainfall.
Many thanks.
Many thanks.
The 4000 is nothing like the 5200 and even much more flexible than the 4200 and not that permanent, the reason I'll probably have to re-do ours at some point. You just need a very fine bead to work on the windows, at least that was what we found... I would think again about using the 3m 4000 on your windows. You might be best off removing them and using something similar but less permanent...
that is just your typical weather stripping foam like you can get at the canopy dealer for sealing out the water between a canopy and pickup bed.... you can probably get it at any home improvement center also....Ah.
What about other peoples deck and hull joints. Foam anyone? I've heard of there supposedly being something like 5200 used form the factory but I cant seem to see any on my 88 26D??
Here is a picture of the joint/foam from inside my laz.
Update.
I still could not trace the exact source of my problem but I did seal the chainplates and the windows and so far my boat is dry. However, when I start lowering and raising the mast I think what 'centerline' says about movement of the chainplates will bring back the problem so I intend to use his cure by applying epoxy putty.
I should add also that I have been told of 2 other ex-MacGregor owners, one who had a 26X and the other a 26M, both of whom sold their boats because of the same water under the seat problem, so maybe this is a design problem that MacGregor should look into.
Chainplates and that area are designed to have some movement. I'd be leery of putting something in that area that really sets up and was not capable of movement. We've had the mast up and down since our 'quicky' repair with no problems. Once the mast starts down the shrouds are slack and not moving the chain plates. If you want to spend time on the area I'd go with the butyl tape before trying the more permanent epoxy myself.....t movement of the chainplates will bring back the problem so I intend to use his cure by applying epoxy putty....
I feel that is a pretty poor reason to sell the boat. Even big boats have to have the chain plates re-bedded from time to time. On the board with more X and M's they address the problem and the owners are happy,......I should add also that I have been told of 2 other ex-MacGregor owners, one who had a 26X and the other a 26M, both of whom sold their boats because of the same water under the seat problem, so maybe this is a design problem that MacGregor should look into.
