Foam Luff
220
catalina 320 Perry Lake
Opinions on how much a foam luff improves sail shape on a partially furled head sail?
RichH
Feb 14, 2005
4,773
Best obtainable sail area reduction for a jib on a furler, even with a foam luff, is only about 30% SA reduction. Once you go beyond ~30% sail area reduction the SHAPE of the sail will be BAD.
There are special 'shapes' that can be designed for the leading edge profile of a jib on a furler ... and the combo of foam luff, special shape, and precise/advanced furler design 'may' get you to 40% sail area reduction ... before the shape 'goes all to hell'.
Reason for all this: A sail usually has it maximum amount of 'curve' at about 30-40% back from the luff ... and if you roll up beyond this you now only have a board-flat, but severely wrinkled along the rolled up luff, part of the sail exposed. A sail is a quasi-spherical shape, and furler foil is a cylindrical pipe-shape.
Without a foam luff you 'may' get 15% roll-up before the shape becomes BAD: with a foam luff you 'may' get 30% before the shape goes BAD.
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
While I don't disagree with what Rich has to say about sail shape theory, my personal experience with a number of boats/sails is that (1) I would never again buy a headsail with a foam luff as I don't think it improves performance measurably (I have a 150 with a foam luff, and a 120 without), and (2) I've found I can roll up any amount of headsail on my furler and, even with an ugly luff, still do hull speed if the wind is howling. Read some of around-the-world-sailor Webb Chiles' books for a similar opinion.
495
Catalina 30 St. Croix
If the wind is so strong that you need to do a partial furl, then the shape is not very important. In my ex 51 footer I had a North 135 with 3 lines sewn in the luff instead of foam. They vary in length depending on the amount of furling desired. I used it for 7 years before I sold the boat and it kept a decent shape. The boat went up wind very well with the main also reefed 25-28 apparent and doing 7 knots.
Gunni
Mar 16, 2010
5,937
What size genoa are we talking about? On my 130 the foam inserts allow for good shape down to 100 size. But I wouldn't want that 130 blowing out and I don't want to haul it down in a breeze.
Interesting that Warren mentions Webb Chiles. I share Chiles evolving perspective: With the advent of furling Asyms the big genoas make less sense. My next headsail will likely be a furling 100 blade, and my Asym will go onto a continuous line furler and retracting sprit. It is getting easier and easier to singlehand a spinnaker. And that is a good thing.
Oct 15, 2009
220
Thanks for the opinions. I have a 125 genoa on a Catalina 320. It has been pretty windy so far this season so I have been sailing reefed often. I agree with Warren that I have had no trouble hitting and even exceeding hull speed (new clean bottom) with my current sails so maybe an investment in a foam luff isn't such a great idea.
Bill
May 28, 2009
764
Hunter 376 Pensacola, FL
Speed's great, but what about your ability to point? We've noticed when the wind tops about 22 to 25 knots, with our 100% jib rolled up a third of the way and a double reef in the main, we can sail just fine and plenty fast, but no closer than about 80 degrees apparent, which is a pain when that's the way home lies.
Oct 15, 2009
220
I agree that pointing suffers when the genoa is reefed. So back to the original post ,would a foam luff help with pointing?
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
I have a foam luff and the shape is much better, but perhaps some of the difference I discern is due to the furler not the foam. My point is that a furler without a top swivel, such as a CDI ( which I had on my old boat without a foam luff) is likely a big part of having a decent furled shape.
