Interesting data, thanks for posting it.
I'm interested in what you are doing for 'fusing'. In parallel you can put a small fuse on each panel so that if it shorts internally the amperage from the other panels can't go to it as that will blow the fuse.
In series you can't use the small fuses since all of the amps would blow them if in series. If you just use one large fuse on the circuit then what happens if a panel shorts internally? Is there a chance that it will burn.
I'm going to stay parallel for sure and hope that we are 'over paneled' most of the time and run the boats diesel or the Honda generator for the few times we need more,
Sum
[FONT=Arial, sans-serif]Our Endeavour 37[/FONT]
[FONT=Arial, sans-serif]Our Trips to Utah, Idaho, Canada, Florida[/FONT]
[FONT=Arial, sans-serif]Our MacGregor S Pages[/FONT]
[FONT=Arial, sans-serif]Mac-Venture Links[/FONT]
Sum
