prop anti fouling
224
Beneteau 35s5 bristol ri
my prop seems to be getting very badly fouled after only a short period of non use. any ideas on what I should be putting on the bronze prop and shaft prior to launching?
May 7, 2012
1,633
Hunter e33 Maple Bay, BC
thetone, I applied Pettit zinc coat barnacle barrier during a haulout one year ago. The boat was hauled last week for a purchaser's survey and the prop and shaft were free of any sea growth. Lots of comments on other forums, most good, some neutral about the product. You can pick it up at West Marine. Before I will consider it for the prop on my new Hunter 33, more research is needed given the aluminum saildrive it is fitted with. I will have to confirm a lot of things prior to using the barrier.
Hunter 29.5 Gloucester, VA
We use a diver down here from May-Oct once a month. He cleans running gear, through hulls etc and carries a bag of zincs so if he is down there and they need replacing they get done. We get a report on condition of the bottom when he is done.
Oct 1, 2007
1,865
"Bag of zincs" ???? How does one carry a bag of zincs and maintain neutral buoyancy?
Dec 30, 2009
680
jeanneau 38 gin fizz sloop Summer- Keyport Yacht Club, Raritan Bay, NJ, Winter Viking Marina Verplanck, NY
prop
Tone, I have used the petite zinc barnacle barrier coat, also, did not seem to work well , salt water raritan bay. Should we use bottomcoat over the zinc coat???Red
Sets his bag of zincs on the dock and if he needs one he surfaces and gets one.
Jun 4, 2004
834
Hunter 340 Forked River, NJ
Barnacle Free
I have used the same method for the past ten years and never have more than one or two barnacles on my prop or shaft. I clean the stainless steel shaft and bronze prop down to clean metal with a wire brush on an electric drill. Wipe with solvent and apply two coats of a non-metallic primer. I have used Interprotect successfully but other non-metallic primers work as well – even Rustoleum primer. I then apply two coats of any available copper based bottom paint and splash the boat. Don't prime or paint under or over the zincs. As I said, little to no fouling after six+ months. I use the boat almost every weekend and motor perhaps for 30-60 minutes total each time we take the boat out. By the end of the season, the paint has mostly worn off the tips and parts of the prop blades but is intact elsewhere.
I have tried this method without the primer and always got bad fouling of the prop and shaft. Interlux outdrive spray works well if used with their primer but is more expensive. I have heard others theorize that the electrolysis current set up between the metal shaft/prop and plain copper paint somehow keeps the copper inactive and thus allows barnacle fouling. A non-metallic barrier coat of primer stops this interaction and allows the copper to inhibit growth.
I sail in the salt waters of Barnegat Bay NJ and keep the boat in Forked River - a somewhat brackish river feeding the bay.
Apr 22, 2001
497
Hunter 420 Norfolk, VA
I have been using almost exactly the same technique as John describes in his first paragraph (Interlux InterProtect, then a hard bottom paint like Petit Trinadad) for the past several years, with the same excellent results that John describes.....
So, I guess it also, "works for me".
