I have developed a leak in the rudder shaft that is fairly significant. It fills the 40 gallon bilge in a matter of 2-3 hours running the boat. It does not leak at the dock. It appears that either it leaks when the stern "squats" under power or it is the movement of the water that forces it up. I went below while cruising home last night under power and took some pics. Do other 33 owners have that same fiberglass cross support ABOVE the stuffing box? is the compression material the same as the prop shaft? If so is it the same size?
