No thats not 'normal'. Its fairly indicative that you have a quite severe 'infection' of microorganisms, chiefly fungals (Cladosporium Resinae, etc.) in your tank. To remedy the tank and the distribution lines ... AND the 'vent' and fill line should be thoroughly cleaned; after cleaning a small amount of new fuel should be used and 'recirculation polished'. Then a 'bacteriostat' / anti-fungal stabilizer should be added to any new fuel you use to 'fill' the tank. Even with new fuel and cleaned tank, you can experience 'slugs' of such 'slime' for quite some time, so plan on changing filters for some time in the future until the tank and its distribution lines thoroughly 'clean out' and the tank reaches some level of 'equilibrium'.
Once 'infected' and no matter how well you clean the tank, etc., you will have to use a 'bacteriostat / anti-fungal' additive to keep this 'infection' from returning.
If you want to delve into the cause more deeply, do websearch for 'kerosene fungus' or "Cladosporium Resinae". Has nothing to do with how much water there is in the bottom of the tank.
A simple 'polish' or 'recirculation polish' of your fuel will not be of benefit (and will be a waste of time and money), you must clean out the biological 'slime' and the actual fungal cells growing on your tank walls, and you must use a 'bacteriostat' in your fuel for the long term future.
This is an INFECTION where the funguses are using the fuel as their nutrient source, the 'black slime' is old dead and dying fungus cells and their products of cellular metabolism - cellular 'poop'. This 'slime' will easily extrude through 'filters', does not 'burn' well in the combustion chamber and will eventually result in your exhaust system (manifold) + water injection elbow being blocked by 'coke'.
