GFCI Trips at the dock receptacle
DSELR
12
Hunter 31_83-87 Lake Ouachita, Royal, AR
My marina operator just came through on a very old dock and installed GFCI receptacles. When I connect my boat, the GFCI trips. This does not happen when my neighbors try connecting to the same receptacle.
I've checked one of the sockets inside the boat and the polarity is correct.
From here I need some trouble shooting tips.
Jan11
Apr 9, 2012
52
Ericson 35 Albany
Start by energizing your boat with your neighbor's power cord. See if the problem is your power cord.
Mar 14, 2012
131
Beneteau Oceanis 40CC Brisbane, CA
Try your neighbor's cord connected to his dock box outlet first to make sure your GFCI was properly installed. If you confirm the problem is on your boat check to make sure you don't have the neutral (white) line bonded to the ground on your boat. If the AC ground and neutral are connected after the GFCI it will trip.
Oct 30, 2011
542
klidescope 30t norfolk
gfci at dock receptacle
it's the polarity light on your AC panel inside boat if its an incandescent bulb the gfci is sencing the load and tripping I had to replace mine with the newer led light
bria46
Jan 15, 2011
286
Oday 272 Waukegan, IL, Sarasota, FL
If you have any GFCIs on your boat, the on the dock will trip. GFCIs tied down stream from one another don't like it.
May 24, 2004
7,230
CC 30 South Florida
Yes, bria46 is correct. Had some isssues with the battery charger tripping the ac breaker on a private dock. I consulted a licensed electrician with experience in marine dock installations and after asking a few questions he recommended we pull the GFCI breaker. Problem solved. It was his experience that GFCI on docks did not really provide any protection and were the cause for many conflicts with boat components. I do keep GFCI outlets on the boat to protect when using appliances.
Good point. That's a much better explanation of why they say that you only need ONE GFCI to protect downstream in any circuit.
