I was prompted to dig into the plans from my Luger 30 project. The Luger has a 34' mast and uses a gin pole that is attached to the fore stay with a tang. It uses the sheet blocks to hoist the mast. So far all of this is pretty common in raising a mast solo.
The unique feature of this setup is in the shroud tensioning device. This is the first time I've examined it closely. The short aluminum pole that runs along side the upper shroud has a block that tensions the upper no matter what position the mast is in by essentially creating a pivot point that is even with the tabernacle. Not only does it tension the shrouds as it goes up it also provides stays for the gin pole.
This system can be used for any masthead rigged boat where the side shroud are aligned with the mast.
