Overheard At The Marina Today
11,772
So I am installing a cockpit table for a customer today and it was a nice and peaceful but crisp spring day.
All of a sudden from a commercial dock across the way..
Rrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
rrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
Literally the motor was cranking for at LEAST sixty seconds. At this point I am sensing the smell of burned starter cables. They take what amounts to a 5-6 second break from cranking, I hear some yelling, some four letter words and then....
At this point I am feeling bad and I yell CLOSE THE SEACOCK! Immediately I hear another 40-50 second blast, after just 5 seconds off, then.....
Rrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
clank..............................................
Now the swearing really starts and they start blaming the batteries for being dead. "Press the f'in button.." "I did, it's just f'ing clickin'", "f'in batteries are brand new"....
Yep hydrolocked by cranking too long with the seacock open.... Could not see what the boat was as it was behind a break wall & a fish pier but it was definitely a diesel by the sound..
It was somehow eerie to know the outcome before it happened. After the second burst I yelled CLOSE THE SEACOCK,as loud as I could, but clearly they were not listening or the wind was in my favor not theirs. I suspect they could hear me as I could clearly hear them despite the distance across the way...
Rough day for those guys but entertaining, in a sad way, like a funeral...... Poor guys were already in a bad mood...:doh:Not a good way to start your season.....
CalebD
Jun 27, 2006
1,479
Tartan 27' 1967 Nyack, NY
Good for you for at least trying to warn them.
Given what you describe though these fellows do not sound like the most boat savvy types.
Jan 4, 2006
7,853
Hear that Quite Often in Our Marina ..................
.............. It's just the sound of another power boater going through spring commissioning of his boat :eek:.
If he ever does get it started, he's off and running.
Jun 6, 2006
6,990
I believe this qualifies as "snatching the pebbles from my hand, Grasshopper"
Welcome to the club. You might want to pick up a copy of Ian Rand's "Atlas Shrugged"
You'll understand later and thank me.
Jan 4, 2010
1,037
Farr 30 San Francisco
Two ways humans learn, rote and trauma. Trauma is more effective. Next time he will close the seacock.
11,772
Yeah read Atlas Shrugged in 8th grade... Ayn Rand was waayyy ahead of her time... My daughters favorite doll is named Ayn.....:D
May 28, 2009
764
Hunter 376 Pensacola, FL
Provided they ever figure out what happened. Some people never learn, afterall.
BTW, it's Ayn Rand (pronounced Ein, not Ann).
May 11, 2004
273
RAPTOR Hotfoot 20 Ghost Lake
You'll quickly realize I know nothing about diesel engines but I gotta ask:
What does closing the seacock have to do with starting ???
Oct 2, 2008
3,815
Pearson/ 530 Strafford, NH
It wasn't me ,,, I'm innocent ,,,,,, this time. I just thought about the talk I had with the customer service pro at the yard where we're keeping our cruising boat. It was about re-commissioning the engine and generator. I asked them to do the start-up when it was put in. Feel great about the choice now. Oh yeah, my worst four letter words include rain and snow.
MS you should have just yelled out your cell number.
All U Get
Sep 28, 2008
922
Canadian Sailcraft CS27 Victoria B.C.
When starting the engine the water pump is bringing water into the system. When the engine is running the exhaust pushes the water out. If the engine doesn't start quickly - say 30 seconds - the water builds up and without exhaust pushing it out it fills the cylinders - called hydrolock.
Tim R.
May 27, 2004
3,626
I will add that the water actually back-fills the cylinders. The water being pumped in gets to the mixing elbow. Because the engine is not creating much exhaust, the water builds up but does not have enough pressure to overcome the water lift muffler. When the exhaust valve opens the water takes the easiest path which is back into the cylinder through the exhaust valve. Water cannot easily be compressed so once in the cylinder, it literally locks your engine.
arf145
Nov 4, 2010
498
Beneteau 331 Deale, MD
As long as we're on this, how do you get the water out of the cylinders once you're hydrolocked? Pull the injectors and suck it out with a pump? Then what? Dry them out and change the oil?
11,772
If you have glow plugs those are often easier to pull but yes you pull the injectors then turn it over to expel the water. Some mechanics will then fill the cylinders one at a time at BDC with Marvel Mystery oil or just spray in a load of WD-40 and keep turning over slowly by hand before firing it up. Multiple oil changes are often necessary because owners continue to try and crank, not understanding what happened, forcing compressed water past the rings and into the lubrication oil.
The most dangerous hydrolocks are when someone connects a garden hose to the raw water intake to winterize or flush the engine. The engine often fires up before it hydrolocks and is spinning at 1100 RPM before the water is not compressible. This almost always results in a thrown rod or bent crank....
One of the dumbest inventions of late is made by Forespar. Called a flushing seacock. It can actually cause owners to ruin their engine because they DO NOT state anywhere in the directions NOT to connect a pressurized garden hose directly to the garden hose bib.....
Hydrolocking can also occur from having a scoop strainer that faces forward or a failure of the engines siphon break.
Nov 6, 2006
10,253
It is good that Yanmar engines have the compression release.. allows one who's made that mistake once to clear the engine very quickly..
Hunter 29.5 Gloucester, VA
Another thing to watch is your impeller. Happened this year with mine. We replaced fuel lines and filters and were having trouble getting bled out. I remembered the hydrolock problem. We shut off the seacock and finally got the motor running but found no water coming out. I pulled the pump and checked the brand new impeller I put on the weekend before had lost 3 vanes. Don't know how you get around that one. Luckily I had a spare on board.
