I have a raw water feed sorted out.
Is there any part of the exhaust that I can share? I believe that I have to run a completely separate exhaust.
Can I split the diesel feed? I was planning on doing this before the first filter so that if one clogs it won't stop the other.
I may have an extra return. There is a sealed off tube coming out the top of the tank but I can't see the interior so I don't know if it is a feed or return or something else. Is there some common item that this is likely to be? Can I share a return or will the pressure from the running engine mess with the other diesel?
