There are a lot of solutions for mast raising, gin poles a frames, and the old he man method
I give you credit for getting it done! With that being said, my method has always been the he-man method. My 30 year old brother he-mans it up I pin it in
But, this weekend after two years of scouring the interweb, I built an A frame system and raised the mast alone!
I borrowed from several idea's out there. I have the O'Day 26 Joe aka Trinkka talked about.
What I did was buy two 1" thick 10' long conduits from Home Depot. Three eye bolts 3/8" thread, and lock nuts and washers. Then I had to go a local Fastenall and buy n eye nut! I had no idea it was called that so it was a challenge to find. I knew what I wanted but did not know the name of that eye nut.
I was at Wallmart and and saw rubber feet 1 1/8" and bought them as well.
Then I drilled holes at the feet of each pole and attached the eye bolts. I had two carbiners and snapped them on the eye bolt and then to the littel bracket there at the base of the stanchion post. The stanchion posts are very close to being in-line with the tabernackle though lower as the tablernackle is higher up.
Then I layed the the conduit on top of one another and drilled a single hole through both. I put a longer eye bolt on there, and screwed the eye nut as a nut on the threaded side. So, I ended up with an eye on each side. I then took my traveler assembly and attached it to bow, and the lower eye bolt. The line was too short so I attached another line so I could stand at the tablenackle and hold the mast while pulling the line. I attached the Jib line to the top eye on the head of the conduit.
I was worried the conduit would bend or fold, I was worried the job line might snap, and many other fears. However, all went well. I pulled the line and up went the mast. The rubber feet held, and the carbiners held, and the conduit held and the job line held.
I have a few modifications in mind. I have a winch lying around and will use that. I just ordered a remote for it.
So basically I walk the mast up but use the existing tackle as a pulley system and the conduit for stability. Either I planned well, or God watches out for fools, not sure which just yet. I will take some pics and you can see the eye bolts and so on. Obviously I did nto take pics doing this! Didn't seem to have that extra hand
My goal was to be self sufficient. Not count on having others around to help, and being able to haul out or launch from wherever I am. Joe, aka Trinka gave me some insight into a launch for Buzzars Bay, and I went out there and looked a week ago. So, I need to be sure I can launch and retrieve on my own if need be.
Believe me, I was shaking after the mast went up. And once it was up, I realized a made a slight error. I did not bring the pin with me for the tablernackle! I had to yell for some assistance to toss me that part.
So, I few minor tweaks and I think it is an ideal solution. As I say I will pst some pics of the parts used.
Happy sailing.
