I've had this issue since 2007 and have been unsuccessful in finding a solution.
Problem: ST 60 Wind instrument will not linearize (no beeps, no flashing numerals/dashes) and (obviously) will not hold calibration for wind direction...speed seems ok.
The operational symptoms are that the heading slowly migrates aft even when headed into the wind. This would lead one to suspect a loose grub screw...not the case...checked repeatedly.
What I've done:
1. Followed the calibration and troubleshooting instructions in the owner's manual. (very slow turns, multiple repeated turns, faster turns, turns in both directions)
2. Checked connections and voltages.
3. Called Raymarine tech support.
4. Sent instrument and sensor to Raymarine for bench testing...both test good.
5. Reinstalled and followed the calibration and troubleshooting instructions in the manual.
6. Checked connections and voltages.
7. Read everything that I could find on the internet on the issue. I found lots of suggestions for trying different things such as set forth above, but I could not find any reported solutions when the initial linearization could not be succesfully completed.
Question:
Has anyone actually found a successful procedure to get the instrument to linearize after having had this problem initially?
What I've done:
Question:
