i have a 1984 hunter 31 that the main 110 volt circuit breaker has died. mine has 5 lugs on the back and a single toggle on the front. it is as wide as 2 of the others. it has 5 lugs on the back. on the corners, one is for black, one is for green, one is for white and one is a white wire that goes to a bus. then there is a center lug that has a green wire that seems to go to the reverse polarity light. it is made by airpax and says it is 37 amp. i cant seem to find a replacement. is the type with a double toggle a replacement? i can cut the panel to accomodate one.
