I'm still working on getting all my gauges working. Right now, I'm struggling with my original fuel gauge. The tank sender was shot, so I ordered a new Wema unit; however, no matter what I do, I only get a full reading when on and empty when off. I'll attach a shot of the connections at the back of the gauge. Based on the original connections (and logic), it seems the center post is 12V in, the left post, marked "S", goes to the center, and the right post, marked "I", goes to ground. I've tried this with the original wiring (which all tests good), and on the bench at home. Regardless of whether the sender is connected to the "S" post, the gauge pegs on the full side as soon as power is given to it (I've slid the float up and down, with no change). I'm grounding the other sender connection to the same point as the gauge.
Time for a new gauge, or am I doing something wrong? The pointer moves in a very nice, dampened way, toward "E", when power is removed, so I thought there was hope for it.
