Why is the advice given to have all the mainsail telltales flowing except the top one, which should be flicking around back about 50% of the time?
I totally agree with Bill Roosa. Whose advice are you taking? If it were possible to keep the mainsail's top leech telltale flowing 100% of the time. then you'd be a god.... but if you're able to get it flowing 50% of the time.... that's normal and good enough.
Why? because the top telltale is very close to the mast and is hard to keep flying straight. The problem is that the mast causes turbulent flow across the sail, which keeps the telltale in disturbed air flow.
On my masthead rig I just have single telltales on the leech of the main tied to the the top three batten pockets. The only windward/leeward telltales I have are the mid-chord set, and I pay very little attention to them.
Some of the posts I've read so far mention headsail telltales.... but that wasn't the question.... so I'll make no comment.
Rich's and Shemandr's comments are interesting.... but, uhmmm... I don't know what you would do with that information though. I mean if you were able to get the top tale flowing 100% of the time, would you be unhappy? Would you constantly play the sheet as the boat bobs over a few waves to adjust the twist? NO.... You're more likely to use the tiller or traveller for those temporary changes and leave the twist set in a more compromised position.
