out board
4
i have a 260 and want to replace my out board 2 strokes by a 4 strokes Mercury big foot.
The 2 strokes have a 20 inches foot, i can replace by a 20 or 25 inches, wich one is the best?
tanks!
Jun 1, 2004
243
Hunter 26 Lake Pueblo Colorado
Depends where you sail, Lake or Ocean with swells. We sail on lakes and have a honda 9.9 long shaft, with electric start, charger and hydraulic lift. I would not trade it for anything else. Do yourself a favor and check out the Hondas.
Sep 29, 2008
4
i sail, on a lake to, is the long foot Honda is 20 inches long?
Jun 2, 2004
3,612
Without a Doubt
I'd spring for the extra long 25" shaft motor
One thing that really surprised me was how much quiter mine was as an XL 25" vs a L 20" but it makes sense since the exaust is 5" deeper in the water.
-na -NA Anywhere USA
Standard is 15 inches, long is 20 inches and extra long is 25 inches. As a former dealer, the question I asked is where you would be sailing. If in the ocean or bays due to following seas or high waves, the 25 inch shaft was recommended but on a lake I suggested the 20 inch shaft. If you feel that a 25 inch shaft is needed, then go with that. The smaller mercurys are built by Tohatsu and that inclludes Nissan. However Honda is a good one as well and invest in the electric start.
If you get the electric start and you have a dual battery system, never switch the battery selector while the motor is running. Otherwise you could destroy the alternator. If you do decide on a dual battery system with battery selector, get the battery selector that has a quick field dissconnect with it as it helps to prevent damaging the alternator if you accidentaly change the battery selector.
Also, all engines now have a zinc attached and you may want to get a spare
Crazy Dave
May 10, 2004
254
Hunter MH 37 Manitowoc, WI
Get a Yamaha 8 HP High Thrust
We replaced the Tohatsu on our 26 with a Yamaha 8HP High Thrust 4 stroke. It was one of the best things I ever did. Better response in and out of the slip, improved fuel economy and it was so quiet. One of my favorite features was the power tilt. No more hanging over the transom and trying to set the support latch!
