Hello
I'm hoping you can help me understand how this works.
I have a Sealand porta pottie that is capable of MSD hook up. The installation instructions are attached and simply show you plumbing the discharge port to a Y-valve that goes to a deck side pump out and/or an overboard discharge. And a plumbing for the vent. I know you have to be 3 miles or so for overboard discharge but I figure if I'm going to go to all of the trouble to plumb it for dock side pump out, I might as well plumb her all the way. The plumbing instructions seem simple enough but...
Here are the issues I don't quite get. The discharge port for the holding tank sits above the tank and exits with a slight incline. See photo....So how does the "stuff" get moving up hill? All of the other diagrams I've ever seen for a marine head have the discharge port on the holding tank exiting the tank at the bottom edge (low point).
1) When they conduct the pump out through the deck plate, do they insert a tube all the way down into the holding tank? If not, how would they be able to suck out the tank if the exit port for the tank sits at the top and not the bottom of the tank?
2) If I ever wanted to or needed to use the overboard discharge, wouldn't I need some way of pumping the holding tank "up hill" to get the "stuff" out of the discharge port? Would I install a mercator, or a hand pump? It just doesn't seem like it would work by simply opening the valve.
In fact the plumbing drawing seems like it would flood my boat if I opened the valve in this configuration. I'd need a loop that went above the water line (yes?)!
Thanks,
r
The photo of the porta pottie is the same unit as mine except I have the 5.5 gallon tank instead of the 3 gallon tank.
Thanks,
r
