I've been reading the "Lack of Fusing" thread -- also other fusing threads often started by Mainsail. Always good stuff.
First my situation and then the question:
Situation: My 110-120v shore power 3 battery x 10 amp each smart charger came with pre-fitted in-line fuses located within just a few inches from each of the +12V battery attach terminals. Obviously, I installed the charger to the batteries as per the instructions = the in-line fuses are at the batteries' plus terminals. I also have a 30w solar panel that feeds into a Morningstar clone type "Duo" (dual) battery charge controller. Currently the + connections from the solar controller to the two batteries are not fused. (I know, my bad).
Question: Can I tap my solar + wires into the pre-fused side of my 110V charger leads so that my solar side is fused from a major short event? Since the solar panel is very low watt/amps and since I very seldom use my 110V charger, seems to me that I wouldn't t exceed the fuse rating even if solar plus shore are working at the same time?
This isn't a money thing. Just convenience and keeping the complexity to a minimum.
Thanks
Thanks
