Do you have a link handy for those clamps? Also do you know the inside dia. of them? I can see some other uses for them and I wish I would of run some of that conduit myself a few places. It would of saved some time later,... you might consider conduit, http://www.lowes.com/pd_72949-223-1...br|0||p_product_qty_sales_dollar|1&facetInfo=
Thanks and I see they have them in 1 inch also. Now I need to remember or go measure some 3/4 PVC and see if that is the ID or ODI used 3/4" conduit.
Definitely a time saver later.
Here's the link for the Conduit Support Strap.
http://www.lowes.com/pd_254891-223-...carlon+pvc+conduit+fittings&page=5&facetInfo=
Here's a pic of my over galley compartment. I used 4ga supply wires from the batt's under the v-berth, it was a little tough getting both of them through there, but it worked by pushing the wires through, some grease would have helped.
Also shouldn't overlook the fact the wires are protected too!
Well, the ones in the laz for example, I thru bolted them. Other areas I used outdoor/waterproof construction adhesive ie., Liquid Nails to fasten a block of wood, then used SS wood screws.What did you use to attach the clamps to the fiberglass?
