the original throughdeck fuel, water and waste fittings for S2's? They have a bigger four-screw flange than many of the current ones. Mine are cast something or other, with black plastic plugs.
Thanks Stu, but nope those are not them. They look like a slighely larger perko or whitecap fitting with an inset screw in plug of black plastic where the newer ones have sainless steel plugs. Perko have o-ring on the plug i believe. These have o-ring in the flange. The are the same 1 1/2 inc I think but bottom of the plugs are not interchangeable.
Wilcox Crittenden. They are made from marinium, some type of aluminum alloy. If you find a source, let us know. Ebay? No common replacement cap fits. I tried.
