I found an earlier post from someone with an M-18 who couldn't figure out how to get the port-side end off of the heat exchanger. Well, that's because you can't. Unless there is some magic incantation that I need.
The left side is totally enclosed (see attached pdf, lower image), and I'm having the age-old issue of jammed zinc anode.
How the heck do I clean out a zinc(s) etc that are stuffed up in there?
I studied Mainsail's HX pictures, but his Westerbeke HX appears to have clean-out caps on both ends.
Thanks
Thanks
