Bladder water tanks: Vetus or Nauta
363
Hunter 42 currently in New Zealand
My forward water tank has corroded through, and cannot be replaced without MAJOR reconstruction. I am going to install a bladder tank inside the old aluminum alloy water tank.
What has been boatowners' experience with either of these two brands, Vetus and Nauta, for water taste issues as well as longevity of tanks.
Thanks,
Paul
Thanks,
Paul
Had a Vetus. Water was fine, capacity went to hell. Tanks become round or pillow shaped as they fill. you loose all the volume at the seams and more if the blaader is restrained from full rounding. Mine was under a settee, would lift the access panel 3 " if I filled it full.
Jan 14, 2011
243
tanzer tanzer 28 bathurst nb
mine is plastimo, the first one was past it prime new, it had a hole because the ank had been to long in the store and the plastic dried up, Plastimo replaced it at no cost to me, no water taste issue
