My maxprop is set a B/Y and V/X. I am only able to get to 2700 or so RPM if I am to keep the temp in the normal range. If I push it up tp 2900 or certainly 3000 the temp rises. Cooing sytem has been cleaned so it's not the problem. I read somewhere (can't find it again) that someone had the same problem and dialed back one notch on the maxprop and problem was solved wihtout loss of speed, just higher RPM (3000). I'd be fine with 2700 cruise but would feel better if I knew I could push it harder for a while if needed. No reserve RPM like I am now. Anyone have any recall or info on this? Also considering the autoprop to replace this maxprop if anyone has any comment.
Thanks,
Chris
Thanks,
Chris
