Honda Generator
5
Hunter Hunter28 Port Orange
I'm planning on purchasing a Honda 2000 generator to power my AIRRR air conditioner, 12k btu's. Does anyone know whether that will power the system when on the hook? I have a 30 amp plug at my stern for shore power, that powers the air unit.
Thanks,
Deb
Nodak7
Sep 28, 2008
1,256
Hunter 41DS Punta Gorda, FL
Thanks,
Deb
Nope...it will take a much bigger one than the 2000 to do that!
Mar 20, 2007
500
Catalina 355 Kilmarnock, VA
I run a 16.5 K Mermaid A/C unit on a Honda EU2000 without a hard start capacitor. You have to turn off the Eco-Throttle switch on the Honda, but other than that it works great. There have been numerous discussions on this and other forums on this topic.
Feb 5, 2012
183
Catalina 1990 Catalina 30 Mark II Harbor Island Yacht Club, Old Hickory Lake, Nashville, TN
I disagree; my Kipor 2000 generator runs my 12,000 BTU A/C just fine.
Nodak7
Sep 28, 2008
1,256
I stand corrected!!! My EU2000 does not handle my AC.
BillyK
Jan 24, 2010
502
Catalina 310 Ocean City, NJ
my Yamaha 2000iS runs my 9,000btu webasto without a hard start cap.. the eco needs to be turned off on the yamaha when i start the AC.. and it works HARD to get it going.. but it does get it running.
7,745
Alden 50 Sarasota, Florida
Thanks,
Deb
Before this gets too misguided, I'd suggest you search the archives for similar questions as the issue of A/C powered by the H2000 has been discussed in depth already. The consensus is that it should be no problem to run a 12K A/C IF everything else is working properly. I suspect those who have a problem attribute it to the wrong issue(s) such as the capacity of the Honda rather than inadequate wiring, higher than acceptable voltage drop, inefficient A/C units, etc... as there are many factors that contribute to effectively using the Honda to run an A/C unit.
My suggestion to you Deb is to borrow a Honda from someone nearby which shouldn't be a problem as they are quite popular and try it yourself before prematurely giving up because someone else had a problem.
xsiddr
Jun 14, 2009
34
BENETEAU 361 Worton Creek, MD
I won't go into the dirty details, but I can tell you that the Honda 2000 definately runs my new Cruiseair 16,000 with smart start and will run flawlessly in eco mode. It has to be a newer Cruiseair unit, my original was fom 2002 and that drew too much to ever run on the Honda, bought a new Cruiseair with smart start and we are happy
Aug 8, 2006
340
Catalina 34 Naples FL
honda 2000
There has been a ton of activity and research done on this topic at the c34 website and others. My Honda 2000 easily runs the Flagship 16000 on my C34. However, there is a big article on the hard start adaptor and the cruisair 1600 which states the Honda will run in eco mode. It also states it will run most 12000 btu units. try googeling it.
