http://s1053.photobucket.com/albums/s473/btm0905/
Here is a link to pictures of the 'Granfalloon'. I bought her last November and am in the process of a restore/refit (rescued her from a defunct sailing foundation in MD before she sold to a scrapper). In the pictures you can see is a beautiful 1976 O'Day 25 swing centerboard in need of some TLC. Hope to have her in the water soon...still lots to be done...I am 26 years old and funds are limited, but I am doing all the work myself. This forum has been very helpful to say the least, so I wanted to join and get some feedback from those who have done this before or are in the same boat (no pun intended)...
I have the bottom stripped of all previous paint. Found what I think was an old barrier coat but it was obviously too old or too thin...because I also found quite a bit of gel-coat blistering and one or two blisters going into the glass (note the boat had been abandoned for two years and unknown when the last haul was). Most had water in them and were easily popped and scraped back with a 5-in-one tool and hammer. I plan to grind the edges back with a Rotary Dremel and fair with Epoxy, coat the bottom with Pettit Protect Grey 4700/4701, and top with a hard paint (most likely a Pettit to keep everything the same brand). When the next repaint comes around I will switch to ablative to prevent buildup. Any recommendations on bottom paint for use around NC would be nice as well as feedback on whether or not it is worth the money to barrier coat a boat this old? It seems that the gelcoat is the only layer affected by water intrusion and I don't want to trap any moisture in the hull.
I will be moving the boat to a DIY yard next week for the paint and when they haul the boat, block and stand, and splash the boat for one months rent of $250 (anchors away in Hampstead NC, new boatyard special). When they do this I want to run a new 1/4" line to the centerboard to replace the broken steel spliced line that was previously broken. Does anyone know the length of this line I can't seem to find it anywhere?
Any feedback, tips, tricks, and well wishes are appreciated. I have worked with boats before but this is the first one I can call my own. I will keep this updated with progress as it comes.
