So, I think I know what the answer to this is but, not being a radio-head, I want to check before I step my mast.
I rewired my mast including new antenna cable. I assembled and soldered the cable, being vary careful with the soldering technique and checking to make sure I ended up with no continuity between the core and shield wires, as was stressed in the readings. I was happy that things went vary well and everything tested fine.
Then I screwed the connector to the mast top antenna wrapped the connection with self amalgamating tape and went on my merry way.
Today, while putsing around (and in view of the approaching time to re-step the mast), I decided to put the continuity meter on the connector again at the mast base.
Well, sure enough there is now continuity between the inner wire and outer shield. Now, not knowing the internal structure of an antenna, I don't know if this is right. And, I don't want to cut the tape and break the antenna connection if I don't have to!
Thanks in advance for any replies,
Joel H.
Joel H.
