I had this in Parts Search Forum, But am bringing it up front cause I found my part, but now I need to mount it...
Question 2 is "Where do I put it"...? Top of the mast sticking out the side/ front/back/...?
I have a Davis wind vane, VHF antenna and anchor light at top of mast now...so this would have to stick out to the side to clear. He was thinking maybe off the spreaders...? but where to clear the sails...
Anyone have a pic or recollection of how and where it should be mounted...??
After further examination, thinking it might go on mast top facing forward...
Thinking the as yet "unidentified" bracket with angled rod may have something to do with it...at least it seams to have the same angle as the tube on the wind vane/anemometer...
Thoughts...?
I have a set of Ray Jefferson gauges in my boat...The Knotmeter and the NM log both work (sending and display) and I have no reason to believe the wind speed indicator WD60 and the wind direction indicator WD30 shouldn't work as well...
But I do not have the mast top sending units and cable(s)...
Anyone have a WS and Direction mast top unit they would part with...?
Or anyone familiar with these units, can I mate them to another brand sending unit...?
Cable looks to be phone line or Cat5... easy enough to replace, indicators have "open lugs" exposed on back so minimal hookup required..
Question 1....Is this the right way or is it up side down..? (don't laugh)Buddy of mine (actually new sailor buddy/met on forum) stopped by to look at my boat...
I mentioned the gauges and looking for a sending unit...He says he "might" have something..!!
Stopped by today with this,
looks correct, has correct number of wires..Just need to run some "jumpers" to the gauges to see if they communicate...
Wish me luck...
Thoughts...?
