My 1985 Hunter 22 (bought is Aug - still haven't gone out in her yet) has some long stress cracks on the deck around the mast step. I've recently noticed with the mast up in the yard that the area just around the mast step is very slightly sloped in, maybe that's how it's always been shaped? I've had the mast up while working on the little projects for a couple months now. The rigging has been tuned.
So I just got to the wiring job for the masthead light and vhf cable through the deck with a CableClam. I drilled a hole through the deck near the Mast Step and noticed that the wood layer was wet when I pulled out the drill. Not good. Water must have gotten in through the old wiring hole next to the step (picture is attached) which was "filled" with putty from PO.
So what am I looking at here? How bad could the situation be? I've filled the old hole with silicon and felt around for soft spots. The layer of wood seems so thin compared to the fiberglass layers... I really can't handle a job as big as replacing the wood layer. At this rate I'll never get on the water!
