Woody, why bother?
Am I missing something here?
You'll never have the generator AND shorepower on at the same time, right? Just plug the generator into your existing sp inlet. So why go to the expense of adding another sp inlet when you can use the one you have for the generator when away from sp? Makes the inverter and manual transfer switch a way lot easier, too, since you'll only need the one transfer switch.the reason i ask is ...i am planning to do the inverter and also install the second shore power inlet in order to be able to hook up the honda gen set via a spare shore power cable and inlet.....
