rudder bearing replacement
oaky
Dec 15, 2011
4
oday 27 bath, me
I have a 1986 O'Day 27 with play in the rudder, I would like to repack the bearing this winter and whatever else should be relaced. How do I do this ? Is there a schematic
on line that shows how the rudder works. I should add that I have wheel steering.
RichH
Feb 14, 2005
4,773
The wear on such rudder bearings is usually due to abrasion between the SS shaft and the (usually delrin/acetal) bearing material. The surface roughness of the shaft abrades away the bearing material.
To reduce the bearing wear, the shaft area at the bearing should be polished to a mirror-like surface finish ... using emory/crocus cloth, followed by 'white metal' polishing compounds which are applied to a high speed fabric buffing 'wheel', etc.
Such replacement bearings (for ODays and Pearsons) are available from drmarine.com ... and you have to dig a large pit under the rudder, drop the rudder into the pit to be able to replace the bearing.
There are alternative (better than delrin) DIY made bearings (using WEST Epoxy + Carbon powder + chopped teflon dental floss) on the web .... do websearch for "Pearson 26 + rudder + bearing".
Std. delrin bearing replacement for O-27: http://www.drmarine.com/products.asp?cat=196
5,802
The "freebie" West System booklets have a section on rudder bearing repair.
oaky
Dec 15, 2011
4
oday 27 bath, me
Thanks for sharing your knowledge on this topic. I've been having a heck of a time removing the aluminum rudder cap from the ss shaft. The 3/8" ss bolt came out easy but even heating, tapping, banging and twisting the cap won't releasse from the shaft. Again, any suggestions ?
CalebD
Jun 27, 2006
1,479
Tartan 27' 1967 Nyack, NY
PB Blaster, absolutely.
Most likely the fitting on top of your rudder post has a keyway, or is keyed into the shaft and the fitting (stemhead?). You could consider that this fitting is 'press fit' onto the shaft. If you could rig up a puller tool, like a prop puller, it might do the trick.
Soak with PB Blaster for several days then gentle tapping and/or apply pressure with puller tool.
RichH
Feb 14, 2005
4,773
Look VERY carefully for a VERY fine line on the portion of the aluminum tiller-head casting, especially the 'line' going vertically (perpendicular) through the section that holds the 'cross bolt' .... if so, take a sharp thin and w-i-d-e chisel and begin to 'open' this line ... and the tiller head will immediately separate from the shaft when that line is 'opened'.
