Alcahol Stove
DARMON
Jan 23, 2012
1
MACGREGOR 26M NAPLES
I Purchased A Used Macgregor 26m Without A Stove . Does Anyone Know Where I Can Buy A New Alcahol Stove
I agree. The Origo is the way to go. Had one on our C25, loved it. Simplicity itself. No moving parts, nothing to maintain or break. Shoot, how can THAT be on a boat???? :):):)
May 4, 2005
4,062
I guess its the pressurize alcohol stoves that give the most problems. (from what I read) -where people can't see the flames and burn themselves.
AFAIK, the oringo are not pressurized. but of course alcohol absorbs water, so if the seal is bad, water forms, and you could have trouble getting it to burn.
OTOH, water puts alcohol fires out, and thus the reason so popular on boats.
Dec 8, 2007
303
-mac 26M -26M tucson-san carlos mx
have single non-flush mount origo #1500 you can have free,just cover shipping, i bought the flushmount with cutting board for a much nicer look.
Apr 5, 2010
565
Catalina 27- 1984 Grapevine
I tried in vain to get the old factory stove to work properly, one burner fairly good, the other is a bonfiree. Didn't like seeing alcohol seeping out everywhere when I pumped it up. So it sits in my workshop and occassionally makes coffee, I use a single butane now.
Jan 11, 2012
44
Ontario Yachts 38 4 Trent Port
You can buy a portable butane stove in hardcase for $50 from any hardware store.
Origo alcohol stoves are "marine" but start at about $250 for a single burner.
If you get the latter, burn Methyl Hydrate from the hardware store, 1/3 the price of Marine stove alcohol.
Kestle
Jun 12, 2011
702
MacGregor 25 San Pedro
How fancy do you need to get? Look up alcohol camping stoves on the internet and make one for free. I made one from a can left over and a round aluminum chimney cap. Boils water and heats boat just fine. However, I view less dishes is better, so if you are a foodie, this will drive you nuts. Uses about 6 oz of alcohol to heat the teapot to boiling. To put it out, I just put a bigger can over it. The alcohol stores in plastic soda bottles. Nothing to break or maintain. Fine for two people. If kids come along, I grab the coleman propane stove.
Jeff R.
Oct 26, 2005
2,057
- - Satellite Beach, FL.
Yeah, I think it was second time we used it we overfilled a heating bowl (couldn't see the pooled alcohol in the pan) and lit the stove that came on our GS. Next thing we knew the alcohol in the pan below the burners was also on fire.
Didn't know about putting out the fire with water so I got to clean that nasty powder from a fire extinguisher off of and out of everything in the salon. No matter how careful it's used that crap gets everywhere.
The stove was next to the club dumpster that same day and no one wanted it so off to the dump.
Replaced it with a Princess LPG that worked great with no problems for years and is still on the boat.
Kestle
Jun 12, 2011
702
I use a turkey baster to fill it...much safer way to refill as you worry less about spilling.
However, I am curious...do the recessed origo's have that problem? My old non-origo did, but it sat on top.
Jeff
Dec 8, 2007
303
origo has a one litre removable canister you can take outside or over sink to fill, never heard of marine stove fuel, most people call it denatured alcholhol,sold at any hardware store or paint store.
Nov 8, 2010
11,386
Non-pressurized stoves like the origo 1500 and 3000 are on the whole VERY safe. The vast majority of (rare) accidents involve filling the canister; either refilling the stove with it still lit or igniting spilt fuel after a fill. As noted alcohol burns in a clear flame so it is hard to see. Develop a safe process to fill them and they are very safe.
They remain a very good choice for boats where propane systems are overkill.
May 12, 2010
237
Macgregor 25 Southern Maryland
There was a great article in Good Old Boat magazine about non-pressurized alcohol stoves a few issues ago, that talks a lot about the advantages and disadvantages of alcohol stoves. Might be worth a look.
Oct 26, 2005
2,057
Jeff
This was an old pressurized stove and we (I think it was me) overfilled the bowl that warms the burner before it can be lit.
I understand the non-pressurized are much safer for klutzes like me.
Nov 8, 2010
11,386
Back to the OP, try and find a way to mount the stove so it is fixed and cannot fall over. Some of these 'camping' solution are low cost but are not designed to be used on a boat. Better still if you can gimbal the stove. The Origo gimbal mounts fit both the 1500 and 3000. Here's a 3000 on our 26 footer. The pot holders are also a nice add and keep pots on the burners.
