prroots
IF the controler is truly MPP then it would work on a 5 volt panel and you would get a 4ish volt output under 1 sun. The problem is 4 volts will not work to charge at 14.4. the real reason panels very is because they are designed for different applications or designed before MPP became popular. General wisdom was you need to be able to provide 14.4 to charge your batts and once you get the panel under full sun it will get hot and loose some volts or when it is a cloudy day it will not be producing full voltage so they generally went with 36 cell panels = 18ish volts
The bleeding edge controlers have mpp and a buck-boost converter (DC to DC voltage transformer) so you can hook up just about any panel to it and it will charge your batts, even a 5 volt panel.
