My dodger is the Catalina Factory Dodger which is the exact perfect height that when I stand at the helm it is right in my line of sight, So I would like to drop it around an inch. My thinking is that if I cut the 4 support poles an inch each that should be enough to drop it and then I can get the dodger reworked so it now fits. I attached a drawing that while not very good hopefully get the point across. So if I cut 1" off of each of the four legs will get me where I want to be? Admiral is skeptical. Also, can I get away with using a plumbing pipe cutter? I am thinking it will make a nice clean cut, but I wonder with stainless steel being so hard.
