I've got a 2001 Hunter P420cc with 2 Lifeline AGM 4DL batteries. They are getting to be about 10 years old now. Though they still seem to be running well, I'm preparing to embark on a SURFMEX cruise from San Diego, so I'm considering buying an additional battery or two to add Amp Hours as well as provide a newer backup bank. I know very little about my battery systems and I like to post some of my questions here. I attached a pic of the control panel for the batteries.
1. I get that the top round switch is for the starter battery (interstate deep cycle 750 crank Amps) and either in the off or on position is self explanatory. However, I'd like to know if the on/off position isolates this battery from being charged by the Freedom Marine 20, 2000 watt / 100 amp battery charger monitored by a heart interface. In other words does the starter bat get charged regardless of whether in the on or off position?
2. I believe that the lower round inverter draw selector switch is set-up with one of the AGMs on 1 and the other on 2. I'm one of those people that just leaves it in the both position because I don't understand why I'd want to use one or the other besides just as an isolated backup, but I'd love a brief explanation, also will both batteries always receive charge regardless of the position that switch is in?
3. There are also two toggle switches labeled panel 1 and panel 2. I don't know what these are supposed to do. I need to have at least one set to on to get power to the panel but it doesn't seem to matter which. I thought that they might be wired to the individual house batteries so I could invert from just one of the pair while running DC from the other, but with just one switch in the on position, both batteries seem to drain evenly, as far as I can tell. So why are their two panel switches? and does it matter if 1 or 2 or both are on, and if so why?
4. I don't have much knowledge on heart system either, maybe someone may know what it should be used for in my set-up?
5. Whats the best way to add one or two more batteries to my system? Can I add just another 4D to the system or will I need to add two? or could I add one 8D?
6. I read that the batteries in each bank need to be the same size and age. So does that mean I should take the two old 4D's and run them in series together into the #1 side and then run a third 4d or 8D or possibly another type into the #2 side?
7. Can I use cheaper batteries for the second bank like 6V golf cart batteries?
I know it's a lot to ask but I'm trying to keep it concise so that other battery noobs may benefit as well.
Thanks, J
Thanks, J
