What have I gotten myself into?
11,724
Quick question about the AC circuit breaker. It is a dual breaker attached with one switch. It is a Airpax and I could not find a replica anywhere. Is it two 30 amp circuits or 2 15 amp circuits? The boat appears to be wired for 30 amps. Why a double breaker on the AC circuit? I couldn't find anyting about the circuit board online for a 1979 Cherubini. Any ideas?
The main AC breakers in boats break both the hot/black wire and white/neutral wire thus the two poles. The branch circuit breakers only break the black wire and are single pole.
Have fun with your boat. You're doing the right thing by learning and reading.. Pretty soon you'll be having lots of fun... Don't let it get you down as there is light at the end of the maintenance tunnel...
May 4, 2010
68
hunter 33_77-83 wilmington, NC
Welcome to the world of Cherubini :)
I got my 1978 33' in May of 2010 in Savanna Ga. My boat experience up to that point was all power boats. I did take the ASA 101 course and recommend it to anyone starting into sailing.
Although mine was in very sound shape structurally there were many issues. The scariest one for me was the Thru-Hulls. I HIGHLY recommend having those looked at asap and reading the How-to info that Maine Sail has a link to in his post. VERY helpful information there.
william
winddragon.net
Oct 27, 2011
154
Hunter 1980 Hunter 30 San Diego, Mission Bay
Congratulations on your purchase. My inlaws purchased a 37 footer as their first sailboat. They had no sailing experience - he had a little motorboat experience. They lived on the boat in the Bay Area for a couple of years - mostly motoring around - then sailed to Tahiti. They never took any lessons, but did read a lot.
Is that how I'd recommend doing it? No. But it can be done. Good luck with the boat. Its a beauty.
Gary
Jun 3, 2004
298
'79 Hunter 33' HUN33190M79L Olympia
Quick note about surveyors and thru-hulls. I hired a surveyor when I was trying to decide whether to pull the trigger on the purchase. After examining the boat for a few hours he gave me a list of items that were okay and a list needing repair. After he left and after I decided to purchase the boat, it occurred to me that he had not mentioned the thru hulls on either list. I fumbled around looking for thru-hulls. One turned and turned endlessly it seemed, confusing me (it was fine, it's designed that way). Another one snapped off in my hand when I tried to close it. I called the surveyor and complained. He got angry. The point hit home: Knuckleheads are sometimes right and experts are sometimes wrong.
11,724
Stephen,
If his survey do not include a section on seacocks, thru-hulls, hoses and clamps then he was not properly surveying to NAMS or SAMS acceptable standards. A call to his affiliated organization, either NAMS or SAMS, may have been prudent as guys like this should not be allowed to continue to perform like this. If he was not a NAMS or SAMS surveyor he probably should not have been used...
This is just a small portion from our 32 page survey on our boat.
"In general, the fluid lines penetrating the hull at, or below, the load waterline are connected to bronze through hull connections which are adequately secured to the hull with proper backing, which was laminated glass fiber. Three seacocks demonstrated “stiff” but positive operation, and will require just routine servicing and greasing (see recommendations).
All hull penetrations were observed to be double clamped with all stainless labeled perforated hose clamps. The bands and screws were observed in good condition with no rust. The male hose adapters appeared to be long enough to engage the double clamps.
A light green patina of verdigris was observed on all seacocks but no corrosion or demetalization was present, except for the sink valve. Scraping the sink drain sea valve showed it to be showing some signs of demetalization evidenced by a pinker than normal appearance to the valve body. This valve was not identified as a Marine UL valve and had labeling consistent with a non-bronze valve. (see recommendations)
The seven below waterline seacocks should be permanently labeled for function and damage control plugs on lanyards should be installed in way of each through hull penetration below the vessel’s sheerline. "
Nov 14, 2006
93
Hunter 27 Lake Lanier, GA
another thing about surveys is that you may need one for your boat insurance. A survey will also tell you what needs or has to be repaired versus things that can be put off. When we purchased Dragonfly I knew she needed a bottom job, a new UV cover on the roller furling jib and some leaky hatches looked after. Now 2 years latter the bottom has been completed, the UV cover was replaced upon purchase, the leaky hatches are dealt with with some Sunbrella hatch covers (they still leak if not covered) and hopefully this spring the nonskid will be finished (see Kiwi grip in the SBO store) and the running rigging that was "serviceable" in the Survey will be updated....its all a process....an evolving love story------enjoy!
Dec 22, 2011
5
Hunter 33 Cherubini San Francisco Bay Area
william
winddragon.net
What was wrong with your thru-hulls?
May 4, 2010
68
This is an image of Galley Sink thru hull valve, located under the port side salon seat, that a previous owner installed. It is a 1-1/2" gate valve made of, I believe Yellow Brass, like you will find in your Home improvement or Harbor Freight type of store. Yellow brass is 33% Zinc and the Zinc gets eaten away over time because of electrical currents created by different metals in salt water.
After reading about this issue on the boat owners forums I sealed off the compartment this valve was located in. Any pressure or impact on this valve would have very bad results! The image you see is the result of ONE whack with a normal claw hammer.
I highly recommend reading Maine Sails How-to about this.
You are welcome to read about my progress on fixing up my boat here WindDragon
Dec 22, 2011
5
Welcome to the Hunter 33 Club!
I too bought a 33(1982) that had come out during Ike and came to rest 300 feet away against some apartments
There was a gash 15 feet long, 2 inches deep along the starboard side, staunchions were ripped apart, and lots of water inside
I didn't even know what side was: the boat looked horrible, had no bow rail, no stern rail, mast was resting on top of boat, no shrouds, no sails
First thing I did was dry the boat out and close companionway
Then I removed the smelly carpets and put foam insulation and covered the whole boat, including V berth, with aromatic cedar panels: I poaid $ 3.00 per board, tongue in groove, 4inches wid x 8 feet long
I had to put in furring strips and press them against both sides, using liquid nail; the rest was easy
All that effort cost me about $ 75. 00 ( yes, seventy five dollars)
I removed the wood inside and copied and replicated all the wood where the drawers are, starboard side, was about $ 50.00 in total
I found a scrapyard with a similar boat, and got what I needed
But do a little bit at a time: I must have spent $ 1,000.00 in total, but have been offered $ 15,000.00 for the boat
Did I tell you what I paid for the boat? One thousand dillars
It will be 2 years now that I have her, and no money can pay for what I have done, it has been a labour of love
The comments about" sell the boat and get a tax relief" are not applicable: you have a simple choice: either buy for a little money and enjoy the work, or pay a lot and get no enjoyment for the work ahead
I am not Rockefeller, I'm the other feller, so I have no regrets.
Have I had problems?
First time out, lost control and hit a sand bank, had to be rescued
Best $125.00 I ever invested was with Boat USA membership: one towing will set you back $400.00
I can send pictures if you want of what I did, but whatever you do, let the good people on this forum (all of them) assist you and you cannot go wrong
Heck, I'm portuguese, we discovered half the world, and I didn't know a thing about sailing!
So there is hope for you
Happy sailing, we await with bated breath your news
Jorge Fife
Yes, please send pics. I am looking for a glimer a light at the end of the tunnel. Sounds like you did a great job with the boat.
Hunter 37C McCormick, SC
Merry Christmas,
As you see, everyone on this site is ready and willing to help. For a couple, a 33 ft boat is not too big. My first sailboat was a 1979 H30, and I sail alone. Having found a mate, I did buy another Hunter, 1980 H37c. Needed more room! My slip seemed tight the first few times I docked, but it was still a good desicion to get her. I am not going to reiterate all the great suggestions, but one. While doing repairs, do not forget to sail ! I joined a race team for wednesday and weekend sailing to get my fix. Get on opposing teams and have fun with it ! Also, I have a real mattress and get the best sleep in my life.
