When I got my boat the VHF antenna and the anchor light wires (2) were run externally down the back stay to the transom thru the locker and to panel and radio respectively...both are functional...
I do not have a steaming light... in the process of wireing one in I question weather I should run it "up, out and down" the backstay with the others...run it down and route it thru the saloon to DC panel ( leave others external)... or re route all the wires and antenna thru the keel steped mast- to saloon-to panel...?
The external wires are long enough to go down the mast tube and out a hole at base of mast,(which is already there) but I would have to cut them and splice in a "disconnect" for each as I pull the mast to transport home for the winter...and then extend them to the appropriate place in DC panel and to radio...
The other concern I have is "noise" from the wires banging around in the mast tube at dock and mooring...I've read of several peoples "complaints" of such, but not certain of their solution...
Is it worth the compromise of noise and extra work for the "protection" of the wires in mast, or are they fine running external (they are weather resistant cables) and I should just work out the steaming light issue...?
